slimbo
- Apr 7, 2022
- 2
Afternoon!
I'm currently in the process of building a Sprinter 170 to be a mobile home for my wife and I. I'm planning out my solar and have 4x100w panels (18.9v/5.29a each), with a 40a MPPT controller. I'm trying to better understand which panel configuration might be better for the controller.
Series - This would give me most volts and least amperage, but with the downfall that if one panel is shaded, the entire system voltage drops.
Parallel - This would give me the most amperage and least voltage which means that wiring would need to be substantial, but least impact from shading.
Series-Parallel - Kind of benefits of both worlds...medium amps, medium voltage, and limited impact from shading (compared to a full Series deployment).
Assuming shading, wire gauge considerations and any advantages of the config (ie Higher voltage will start charging sooner with less sun)
My question is this...from the MPPT perspective, would the output charging amps from a full series install (75.6v/5.29a), or 2S2P install (37.8v/10.58) or or a full parallel install (18.9v/21.16a) be best. I have a feeling that I'm overthinking this and volts in = amps out and amps in = amps out. Meaning that whether the power comes in as amps and that is sent to the battery bank, or it comes in as high voltage and is converted to amps, it will net me the same amperage either way (no magic way to create power, right).
IN an effort to make my question clearer, maybe I'l pose it this way.
Assuming full sun on a full series system would give me 75.6v/5.29a, and the MPPT converts the extra voltage to amperage - what would my amperage be? Forgetting loss in efficiency for now, would it ultimately work out to the same amperage as if I had full sun on a full parallel install (21.16a)? IE: is it simple Ohms Law and nothing more involved than that?
