I'm installing a solar setup in my camper van. Everything is currently running off the starter battery setup, and there appears to be some stuff grounded to the chassis. I'm adding a LifePo4 battery that will only be charged by solar initially, and will be separate from the starter battery. I was trying to hook some stuff up to the new battery, but I'm finding a bunch of the grounds are connected. I think this is because of some of the stuff being grounded to the chassis at the outlet, or chained to other grounds?
I'm using the xiaoxiang(overkill) bms, which is negative controlled(?) In order for the BMS to work, I would need the grounds to be completely isolated, correct? What if something bridges grounds via the chassis? What are the consequences?
I'm trying to think about a common ground system with separate positives, but I don't see the BMS working correctly? But maybe it would? I guess I don't know batteries that well.
