I am installing a multiplus II and am noting that when the ground relay is disabled in victron connect that there is still voltage present on the output ground when inverting from 48V battery. I have not connected AC input yet. My understanding is ground should be isolated from neutral when the relay is disabled (open state). But on this unit, it does not seem that is, at least not fully. Chassis ground is not connected to anything currently. Voltage measurements below with and without the relay enabled.
With relay enabled:
Ground to Line = 120V
Ground to Neutral = 0V
With relay disabled:
Ground to Line = ~70V
Ground to Neutral = ~`50V
(interesting that these two measurements added are ~120V)
Voltage between Line and Neutral on AC out is 119V and the inverter seems to power appliances fine when relay is closed. I have not tried when the relay is open. My concern is the voltages measured on ground with the relay open as I want to connect the inverter AC output to an Interlocked mains panel with grid off where the neutral/ground bonding already exists.
Are the voltages found on ground normal with the multiplus?
With relay enabled:
