jzampieron
Thoughts on the electronics install for my 31 panel Aptos 370W system. This is meant to be a grid-sell net-metered w/ battery & generator backup.
Dual MPPT 100-600 w/ RS and Dual XW Pros.
Strings will be 10s2p and 11s1p.
AC Panel on the Right is a grid-tied sub-panel and AC panel on the left is a critical load panel.
Rack in the front is an EG4 6x 5kWh Lifepower4 Rack (30kWh).
The mounting is 1/2" cement board over 3/4" plywood which is painted w/ Intumescent Paint. Looks good and makes it much more fire resistant.
Need to go out and grade the field for the Iron Ridge racking and get the panels set... will post photos on that when finished.
Note: Panels are not connected yet. Hence the wires hanging out of the Disconnect RS. Running grid-tied backup while I finish the excavation.
100% of the install done by me & my wife.
![20240623_115605.jpg 20240623_115605.jpg](https://diysolarforum.com/data/attachments/224/224102-b2435ec1747f3b4b052db158a587b48f.jpg)
