Recently got a Narada NESR lithium battery connected with Infini inverter. There is no BMS comms with inverter, so I manually set Bulk charging (54v) & floating (52.5v) voltages. My understanding is that when battery is fully charged, BMS will stop charging the cells and charging current will drop to 0 amps. However, the battery has been fully charged for over two days now, the inverter is showing float voltage, but its also showing 2.8amps constantly going to the battery. Is this normal?
Should I set the inverter to stop charging after floating for X minutes and the restart charging when voltage drops to 49v?
