Need to run 220v well on 120v using one ecoflow pro.
dsutherland123
Rhode Island
Need to run 220v well on 120v using one ecoflow pro. I have an interlink on my panel for my 30amp gas generator. Can't afford another ecoflow pro. I do have an external LiFePO4 battery to help prolong the ecoflow pro. I was thinking of a step up transformer that I can wire between the ecoflow and my interlock panel. Would love some help? Thanks.
I was looking into doing somthing similar with an autotransformer with my soft start 240v well pump and a 120v inverter generator. After some research, looking at voltage drop of other leg of the transformer, decided against it. If I find a cheap autotransformer I will try it but not going to spend to $700 on a Victron for a test.
It works both ways but your 120v Ecoflow will not have the surge capacity to start a well pump.
I’m not the OP and agree that his ecoflow wouldn’t be enough. Assume you are confirming the Growatt AT will do step up 120->120/240 split phase? Can’t find any documentation on the taps to use for this.
Video looks like wire wrapped cores. Power will flow both ways.
Need more specs on pump. Do you have a meter that measures inrush? If you don’t have a softstart well pump like a Grundfos, it can take a lot of energy. My 1/2hp submersible ran at 1700 watts but needed ~9500watts to start. A Duromax 10kw generator wouldn’t even start it. Recommend checking your inrush current and post back.
I don't have not know what am I rush is but I believe ( I put it in years ago and lost the paperwork) it's 1 hp and submersible. When I used a gas generator with 3500 watts total, it handled everything well (pun intended).
lI believe
If you could post the specifications of the well pump It would help determine the size of the transformer needed and if the load would exceed the capability of the ecoflow pro.
I am the original poster of this thread. I have a different arrangement for the well. I would like some advice. Seeing as the well pump is the only appliance that needs 220V could I not connect it to my panel and use a step up to 220v and plug it into a 110v socket that's connected to my panel.
Could a 240V submersible well pump run off of a dedicated 230V single leg inverter? My 240V inverter mini split doesn't mind it at all.
Vevor 24V 230V 60Hz 3000VA aio. Can't use the charging function on US 240V but it was only $280 and works great.
