yes this is because internal resistance is going up faster @ a higher amp charge. basically you are not actually hitting 57.4 AT THE BATTERY. use the onboard volt meters on the battery and you will see this. you are probably managing to charge the actual battery to a higher voltage with a lower a charge, but on the charger side a higher imput amperage will result in a higher voltage reading. if you add up the 4 readings on the onboard digital display on the battery, you will get a more accurate( and probably lower) readingI’ve been fortunate with my batteries. With 4 in series I have been able to get to 56 volts from the beginning with an active balancer on the bank. That’s 14v per battery. After 5 full cycles at 30amps I could reach 57v before hitting cutoff but at 5amps I would hit cutoff at 56ish. Now that I have the internal balancers the 30 amp charger hits 57.4 before quitting and 56.8 at 5 amps. I am close to the stated specs now on the charging side but the bms cuts out at 46 volts discharging. It is interesting to me and I have no other experience with lifepo4 batteries so I’m not sure if this is normal or not but a faster charg gets me to a higher voltage before cutoff than a slow charge but low voltage cutoff isn’t that way at all it cuts off at about 46 volts regardless of discharge rate. Now if I have a high (for me) discharge rate of let’s say 40amps the batteries will hit cutoff sooner and if I let them set for a bit I an get another 4 or 5 ah out of them but they still cutoff at 46 volts. I wonder if this is a normal scenario for lifepo4. As near as I can tell I am getting 90 to 98 ah out of the bank and I have yet to test it since I put the balancers in. I don’t have a very accurate way to do a discharge test just load up the inverter till I get a 20 amp load and then set a timer for 4.5 hours and watch the last of it’s discharge cycle and do some math. It’s easier on charging as I can set the charge rate at 30 amps and return in 2 hours and 50 minutes to finish up. That’s not as easy as it sounds because at just over 90 ah in the charge rate gradually drops from 30 amps to 25 and then rapidly to 8 amps and slowly Down to nearly nothing and then the voltage begins to vary between 56.8 and 57.2 which I assume is high voltage cutoff as the charger does the same varying voltage thing if the batteries are disconnected while charging.
