blackbear199
long time small scale user(20 yrs).
wanted to upgrade system at my camp.
currently 3x100w panels series connected to a epever 30a controller with 2S2P 6v 225ah lead acid.
i am upgrading to this..
2 x longi 405w - voc 37.00 - lsc 13.83 in series connected to a epever 40a
2 x longi 545w - voc 49.65 - lsc 13.92 in series connected to a epever 60a
reason i went with 2 strings is space where panels to be mounted,i cant fit 4 x 405w or 4 x 545w
i got a good deal on some used gel batteries
12v alphacell 220 glx 110ah battteries.
they came out of cell towers so i assume they havnt been cycled much.
i am going to connect them in parallel as per a iota diagram i found(see pic)
i dont use much power but what i wanted is storage for cloudy/rainy days.
a 1200w inverter runs all i need and prob only using half its output max at that.
i know with a bank this big i should have went 24 or even 48v but my loads are low and i have stuff that runs off 12v so didnt want to go with a down converter also.
so i decided to get with awg 4 for battery cable everywhere.
from my calculations between the 2 arrays(i am over paneled) on paper i shud get full 40 and 60 amps charging from each controller.realastically more like 85% from each.
i dont ever expect to see anywhere close to the full charging capacity as i watch my battery state carefully and when they get 12.4-12.3 i shut it down as i never over discharge.
i got easily 7-8 years out of lead acid batteries doing this along with always keeping them topped up with distilled water.
i know i shudn have went with awg 2 but the price diff didnt seem worth it to me as i rarely if ever expect to see max charge capicity(batteries dead).
i am also using a iota 90a when needed from generator.14.2v bulk and 13.6 float.
i built a panel during the winter and am going in a week to install at the camp.
i connected everything at home and everything looks fine.
the batteries were near full charge.
after powering it put max currect was like 5 amps and slowly dropped to less tham 1 amp.
i left it connected for a week to let batteries equalize.
just like some thoughts if i under doing it with cable size.
