Maybe s2s is not getting them from growatt USA?yesterday...
Could be but don't know how that interacts with warranty. Definitely had sellers offer it to me on Alibaba. Never have any idea with those vendors what they really have access to or what they're going to chase down if you make the order.Maybe s2s is not getting them from growatt USA?
I'm not sure. I'll have to find out more about thatCould be but don't know how that interacts with warranty. Definitely had sellers offer it to me on Alibaba. Never have any idea with those vendors what they really have access to or what they're going to chase down if you make the order.
That is probably true - Self2solar sells a lot of stuff directly from the Growatt warehouse in the Los Angeles area. IMO, it’s preferred as compared to buys from a place like signature solar who buys them from the same warehouse and then handles and stores them in their warehouse- companies like that add no value from a tech support or warranty standpoint and can damage or mishandle stuff and also ship you the wrong one. Since Growatt is not setup to sell directly to individuals, they rely on marketers to sell their higher end products out of their USA warehouse.I emailed Growatt and they didn't think US distributors had it yet,
That's interesting. I talked to two people at growatt today and they confirmed they had over 50 units at the warehouse, just came in, but the two people I talked to had never Heard of self2solar, which is interesting because s2s has a large selection of growatt inventory.That is probably true - Self2solar sells a lot of stuff directly from the Growatt warehouse in the Los Angeles area. IMO, it’s preferred as compared to buys from a place like signature solar who buys them from the same warehouse and then handles and stores them in their warehouse- companies like that add no value from a tech support or warranty standpoint and can damage or mishandle stuff and also ship you the wrong one. Since Growatt is not setup to sell directly to individuals, they rely on marketers to sell their higher end products out of their USA warehouse.
The ARO batteries I purchased from Self2solar in late March shipped directly from the Growatt warehouse.That's interesting. I talked to two people at growatt today and they confirmed they had over 50 units at the warehouse, just came in, but the two people I talked to had never Heard of self2solar, which is interesting because s2s has a large selection of growatt inventory.
Isn't that a fairly common thing?The ARO batteries I purchased from Self2solar in late March shipped directly from the Growatt warehouse.
The version 2 min-us inverters I purchased from Renvu and San Tan last year were both shipped directly from the Growatt warehouse. The ARO batteries I purchased from Renvu and San Tan were also shipped directly from Growatt warehouse.
It definitely has been for me, I prefer it. Signature Solar is a prime example of a good reason not to buy from someone who stocks the stuff themselves. When I bought a V1 MIN-US from them in May, 2022 they told me you “can’t connect a battery to it because it’s a gridtied inverter “! I bought it from them anyway because I already had a V1 and knew better- signature solar had the best price (significantly) and I didn’t need any support. Nobody who thinks they will need technical support from signature Solar should buy anything from them. Their only redeeming quality is price on a good bit of stuff.Isn't that a fairly common thing?
It would be educational to hear what type of issue you had?when I had an issue with one of the units
Unit reported about half the output that it was actually producing (measured via multimeter) and couldn't function at 100% of rated capacity (once you pushed it beyond ~85% it would cycle the output rapidly, would see the amps drop and climb on multimeter). If you limited output power, no cycling.It would be educational to hear what type of issue you had?
I have a couple of questions about your system:All just run to single 225A load center (with 225A main breaker), which connects to fused disconnect, then Polaris taps that are connected to two more 200A house panels and one set of lugs on the meter.
No batteries so pretty simple.
Not the best pic but what I had on the phone
1. No power metersI have a couple of questions about your system:
1). I don’t see a power meter connected to any of your inverters- but the pic may not be high enough resolution to tell, I’m assuming there are no power meters?
2). I’m assuming you are using them with all 4 gridtied, as opposed to ac coupled to a separate grid forming inverter?
3). If gridtied, I guess your utility lets you feed “unlimited “ amount to grid? If not how do you control it?
4). I’m assuming they are version 3 inverters?
I looked and couldn’t find a post of yours anywhere that discussed these types of details, apologies if I missed one somewhere,
No, the PV01 is meaningless as to what version they are.1. No power meters
2. Yes gridtied right now. Working on adding more solar+batteries right now to have off-grid capability. Will integrate sph10000/18kpv/solark so I can use generic 48v.
3. Yes, unlimited.
4. I think version 1. Parts# starts with pv01
I received 2x of 0065200 and 2x of 0058400No, the PV01 is meaningless as to what version they are.
See attached part number cross reference.
Are those data logger or inverter part numbers? They are right next to each other on the label, on mine anyway,I received 2x of 0065200 and 2x of 0058400
I think it's the inverter. The data logger is 045.0099800Are those data logger or inverter part numbers? They are right next to each other on the label, on mine anyway,
045 would definitely be the data logger. The reason I’m asking is the part numbers you listed did not exist a year ago, which means either you are looking at the wrong number or the part numbers have changed, which would mean the capability of the inverter changed probably. Any chance you could post photo of the PV01.####### number?I think it's the inverter. The data logger is 045.0099800
