kselectric
Hey everyone,just getting my feet wet in solar,inverter,battery bank.I started small with a MPP LV2424 hybrid and a Ampere Time Lifepo4 24v 100ah 2560w battery.
We are having some issues with full charge of battery(CV voltage is set to 29.2v,float is default at 27v in inverter settings) we have a small solar array of 400w in parallel with utility input as needed.Although the LV2424 says the battery is fully charged it will only charge it to 26.8v and stop charging.Does the BMS in the battery need to be reset to charge at 100% capacity,which should be 29.2V?
How do we get the LV2424 to charge the Ampere Time to fully charge,or do I need a separate battery charger?I am confused on why the LV2424 does not fully charge the battery to the settings with either solar or utility.Did I mess up the battery by not fully charging it before first use(discharge)
Any help would be appreciated.
