humeno
I have been investigating my issues with LV2424 shutting down after cloudy days. It seems there are a few issues going on and wanted to see if others who are using the same inverter have ran into similar.
First, the setup is completely off-grid. There are no utility tie at all. I have 4x 200W panels on the roof and the inverter is connected to 2x 100AH LiFePo4 batteries in 2S1P so that they produce 24V nominal.
LV2424 does not have LiFePo4 specific preset so I am using the User defined settings.
What I am noticing is that the it appears that the batteries are not charging all the way. The charging indicator will turn solid (fully charged) when the battery voltage is reading 26.6 - 27V. At that point, according to the battery datasheet, the batteries are only at 20-25% SOC. This tells me that even though I am setting the custom charging voltage higher, the charging profile and the charge cutoff is set to what's appropriate for an AGM battery which needs to stop charging at 13.5V or so.
Is this a known limitation of this inverter? Do I need to switch to an AGM batteries (or use a different inverter)? Unfortunately, I am discovering these too late to return any of the equipment as the 30 day return period is already passed.
- CV - 28.8V (double of the 14.4V charging voltage specified by the battery)
- DC Cutoff - 24V
- Battery priority for Solar
