Jameswy
I just finished building a solar generator with an MPP SOLAR HVLV2424 inverter/charger. I am using (x8) 3.2V 280Ah lifePO4 cells with the Overkill Solar 100A 8s 24V BMS.
Everything seems to work until I plug the inverter into the grid (wall outlet). The input voltage shows 122VAC until I put any type of load on it and then both the input and output voltage drop to like 80VAC including when just the fans spin up a bit on the inverter. When it does this I noticed the BMS shows an over voltage warning as well. When I disconnect the grid power then the output voltage remains constant at 120VAC including when I add a load.
Attached is a images of the inverter during this operation as well as the BMS.
I tried to insert a recording but wasn’t able to do that to show it going from 122VAC to around 80VAC and then once the load is gone it jumps back up to 122VAC on both the input and output. Again it does this with only the load of the fans on the inverter.
