Jameswy
I am almost done building a solar generator using a MPP SOLAR HVLV2424. It is tied to (x8) 3.2V 280Ah LifePO4 cells (24V 280Ah battery). I am using an Overkill Solar 100A 8s 24V BMS.
I am not sure what settings I should use for the following:
Program 14. Battery Type
Program 17. Bulk Charging Voltage
Program 18. Floating Charging Voltage
program 19. Low DC cut off Voltage
Program 20. Battery stop discharging voltage when grid is available
Program 21. Battery stop charge voltage when grid is available
Thank for any help. This is my first build and I am a little nervous about messing something up.
