*No load - no usage - dropping voltage <22V - after sunset CC turns off*
Hi experts,
On setup below, having no active load (inverter off), minimal usage during the day, after sunset, always within 1-2 hours the charge controller turns off.
24V System
2x 460W panels in series
MPPT Epever 60A Charge controller
Inverter: 24V-230V, 1500W/3000W
8x LifePo Litheum 280A batteries in series.
BMS 4s lifepo4
Multimeter reading: 22.1V (now in the morning).
Typical day:
Mornings: CC come online, reading 3.2-3.5V total. I reset CC, typically it reads 22V.
Sunlight: runs up to 28V 100% SOC.
Daily usage: Often nothing at all: charging phone and laptop.
Sunset: in 1-2 hours (even with inverter turned off) CC shuts down.
The reason, and solution keeping batteries operational, can you help with your suggestions, and solution?
What should i check?
Let me know. Thank you.
Hi experts,
24V System
BMS 4s lifepo4
Typical day:
