WilliamC
- Feb 22, 2020
- 61
Background. I have an Aims 4000w 24vdc to 120/240vac inverter. This is for a battery backup during power outages of critical circuits. Like water-well, refrigerator, and freezer. The 24v battery is the main source of power, and the charge is maintained by a standalone Victron battery charger (not the built in charger in the inverter). I also wired in a generator input to the inverter in case of prolonged outages. The generator is a 4000w 120/240vac Honda generator.
Now for the odd advice. I was told I don’t need a neutral wire from the genset to the inverter. Just the two wires, one for each side of the 240vac. That the generator and inverter would make its own ground. I questioned the advisor specifically and repeatedly about needing 3 wires from the generator or two wires from the generator into the inverter. He was quite clear that only 2 wires were needed.
I have never used this generator input, but the question and concern has remained.
