Greetings all.
I wanted to see if someone out there would be able to give me some input regarding the subject line.
Background:
I have an existing, underpowered system with utility interconnect agreement. The system was installed it approx. 2018.
- SolarEdge SE5000H
- 3.71 kWp array
- Average usage = 175 kWh/month
- True up this year will be $500+
I’m looking for a solution that fits below criteria.
Qualifiers:
My thought was to build out a separate off-grid system. The trouble I’m having is understanding how to accomplish the goals stated above without needing to modify my utility interconnect and/or pull permits.
I think I have a basic understanding of how a general system should work. I become confused when figuring out the best and easiest installation to connect the inverter to existing equipment for backup and on demand use - without risking code violations.
How would you go about accomplishing this?
Background:
- SolarEdge SE5000H
- 3.71 kWp array
Qualifiers:
- Does not require utility interconnect agreement
- Does not require permits (Northern California)
- Does not require a critical load panel build out (preferably).
- Does not require a transfer switch (preferably).
- Backup power
- Reduce electric bills
- Future proof for EV charging
- How would you configure such a project?
- Would 6000xp with 14.3 kWh storage be sufficient?
- How would you go about a 50ft run from home through concrete slab (finished backyard) for solar array?
