I have two 25 year old 12V Solarex VLX-32 32 watt panels hooked in parallel that operate a gate. Our old gate was 12V and the new gate is 24V. I'm told it would be better if the panels were connected in series. I opened the lower panel junction box and it was full of ant crud and the connectors are badly corroded. I also see an anode and some jumper wires. I could cut some wires, use wire nuts as connectors and change it to in series. Would that work? Is the anode important? Do I have to buy new panels? Currently, they're generating 17V, which seems OK, and the gate works on sunny days, but there's four houses behind the gate and the two new 12V 7AH batteries aren't keeping up on a cloudy day. Thanks for your help!
