grahamsc18
Hi, looking for an opinion on AMP charge rates for the 2.4kwh Pylon tech batteries / 3.25kwh solar - I have 5x connected in series to a 3KW Solis system and are look for the most optimal, non damaging, charging levels.
Originally the inverter was set at 50 amps, I assume the default after install and I have recently been charging on the Octopus Go nightly tariff @~2.5kwh to keep them topped, however I see Pylontechs data sheet recommends 25amps charging rate so I have dropped this down which obviously is now struggling to get the batts up to near a decent charge each night for the rest of the day (assuming no solar charge).
I was interested to see if anyone has experience/opinions on recommended charging levels i.e. pushing them a bit higher vs the impact on overall life of the battery during the winter - in the summer/longer daylight I never needed to charge overnight so this is for winter months only.
Many thanks in advance!
