Then to me that sounds like a faulty MC4 connection or the polarity is cancelling out the voltage.>Can you clarify that this is still all open circuit testing - as you put in post #3?
No load, nothing is connected to the inverter yet so only the panels and the strings are being tested.
>are you saying that a voltmeter connected to the dodgy panel reads a voltage on its own, but as soon as you connect it to
>other panels, despite those other panels not being connected to anything else, it shows no voltage?
Correct. If I test the panel on its own, it shows good voltage. As soon as I connect it to another panel, in a string of two, there is no more voltage across the two panels.
>Also, regarding the connecting in series.... does this strange behaviour also happen if the panel-in-question is at one end of the open
>string, in the middle AND at the other end of the string?
Correct. this is how we confirmed this panel is not working right. I tried connecting another panel on its negative and get nothing. I tried connecting to on its positive, I get nothing. As soon as another panel is connected, there is no more voltage flow.
>Are the panels just raw panels, or do you have any optimisers or similar attached to them.
Nothing, just the panel/s.
I am guessing it has MC4 connectors. Did you check to ensure that it is not wired in reverse polarity? Your meter should show if the panel when measured by itself is giving you a positive or negative voltage. Standard is the male MC4 is positive and the Female MC4 is negative.
What is the voltage of the panel-in-question when one side is physically connected to another panel?
I guess it's possible since it was never used in a string before, it used to have a micro inverter on it.Is it possible that one or more of the bypass or blocking diodes is installed backwards?
No problem, I'd like to accomplish both. If I could fix the two that aren't working, that would be a bonus.When I say buy new ones, I mean the diodes
did you check to confirm every single panel was good ?I'm making up 7 panel stings. I've come across one that's doing something I'm totally baffled about.
I can measure voltage when it's not connected to anything but if I connect it in series with just one other panel, then it outputs zero voltage.
All I can think of is there is something in the small black box the cables are coming from that disables the output when the voltage goes higher than the panel can output on its own?
Stumped.
not worth checking if both are outputting voltage on their own it just means the connector isn't working there's really no other reason it can be.I've seen the little diode box open on some videos but is it even worth trying to fix if that's the problem?
Sorry, I'm not really following here. I checked every single panel and every single extension I made. I had to make a bunch of 2' extension cables.not worth checking if both are outputting voltage on their own it just means the connector isn't working there's really no other reason it can be.
You already checked polarity and others are having you do it more but it can't be that if the multimeter isn't faulty
anyway take a wire and stick it into the MC4 connector of both of the units and stick them together and then see if it works
yea so the MC4 connectors are not connectingSorry, I'm not really following here. I checked every single panel and every single extension I made. I had to make a bunch of 2' extension cables.
I found nothing wrong with any of the extension cables and the string works, only not with this panel connected. Once this panel is connected on either end of the string, the string shows no voltage, completely open circuit.
