jmckee2725
First system I've done, all good except inverter to solar panel communication issue
2 Sol ark 15k's
52 - Solarever 455 watt panels on barn rooftop mount - 150' away from basement where inverters are
6 strings - 3 to each sol ark
Tigo ts4 a 2f modules - 1 per 2 panels
Tigo rss transmitter dual core kit
I can't get the solar panels to turn on, right now I'm using the B/B pins on master sol ark to go directly into the Emergency shut off button on barn but not using pins 15/16, only using the Tigo rss transmitter with the dual cores powered by a 120v connection as the Tigo website said the sol ark 15/16 pins weren't sufficient power for the transmitter. I originally put the transmitter in basement and ran all 6 negative pv wires through both cores and had no luck, I then read it could be a cross talk issue since I only have one 2" conduit from barn to basement with all the pv wires in it, so I removed three of the strings from the sol ark #2 and still no luck. Next I moved the Tigo transmitter from the basement to the barn so it was closer to the panels, started with 3 strings, no luck, then tried just one and still nothing. I do have dc breakers in the barn where each string is connected before heading to the basement but I bypassed the breakers also thinking they could be the problem, but that didn't work. Please let me know of any other things to try, hoping it's something simple, I will attach some pics of my set up. Sol arks are up and running off of grid power and batteries are full. Thanks for the help
2 Sol ark 15k's
