jaythegemini
Hi there
This is a special scenario I have not found much on the internet about it, nor the installation manual either.
First things first, the schematic for the Meter / Main Combo is as follows...
It looks we have 2 parallel sets of 200A conductors coming off the Meter Base. Both sets are double lugged onto the Meter Base, and respectively feed dual 200A Main Breakers.
One of the 200A Main Breakers goes off to another 200A Panel downstream somewhere, and the other 200A Main Breaker feeds local loads that immediately on this panelboard. Please see the below 2 pictures.
![41924.png 41924.png](https://diysolarforum.com/data/attachments/181/181797-9644be538de7c78c659bfc62a5a1a42a.jpg)
![1de8cdbb-ef0f-4543-a4ac-478e33859c6f.jpg 1de8cdbb-ef0f-4543-a4ac-478e33859c6f.jpg](https://diysolarforum.com/data/attachments/181/181798-91e82ba5ef31ad1201f91710611be517.jpg)
I have been looking everywhere, and I am so confused.
Can someone help sketch me a diagram for the AC side of things? I want to parallel both of the Solark 15K's, then be able to do a whole home backup of BOTH 200A panelboards. How do we accomplish this?
I understand the Solark Manual says to combine BOTH the inverter outputs in a dedicated load center, so I will do that. I am just unsure how to make the final interconnection.
If I do a line side tap, where would it occur? Does it occur at the double lug on the meter base itself?
I am confused as all heck. Thank you guys. I appreciate it.
