averagejoe13
I am looking for a solution to "supplement" whole house from EG4 18KVP. I.e. idea is to have EG4 18KVP inverter produce no more than house is using (for now, without batteries, in future I likely to add these). I.e. zero-export. At the same time to have grid power available when sun is out or when HVAC compressor turns on.
I do have two main panels, each with its own 200A breaker. I want to feed house load through a double pole breaker in each main panels. There is little to no space to put inverter between meter and a panel. And redoing that part is tricky due to how wires enter ting the meter and wires entering the house.
My understanding is that it is possible to splice in second pair of CT sensors to measure L1/L2 combined in both panels.
I will start with a tiny PV array of 10 250W panels, with intention to start small and add PV panels overtime (I have plenty of ground space)
(I am new to all of this, just reading a ton for now) Questions -
1) Is adding/splicing-in another set of CT sensors is reasonable idea? Any concerns I should have besides sourcing right spec ones?
2) Is feeding both panels from the same inverter at the same time can cause issues?
3) How I should calculate proper double-pole breakers amps for use inside each main panel? Should it be 50A for each or 25A for each or 120% of 50A/25A? I am unlikely to have both panels maxing out EG4 18KVP spec'ed AC output at the same time, but each panel can draw close to that at different time of the day/year. (One panel has all HVAC stuff on it, second one have pool heater/pump/etc).
