Texas-Mark
- Aug 4, 2021
- 1,284
1. If you have a grid-tie inverter that has zero export capability, I assume it has to have a CT to manage the zero export, correct?
2. Do all of these zero export inverter have a way to set a threshold for when to stop generating?
3. If you can set it for let's say 300 watts (coming from the grid) as the threshold, how quickly can it throttle down? In other words can it "accidentally" back-feed if the load suddenly drops (i.e. HVAC turns off)?
4. Related to question 2, if lets say a 120V grid-tie inverter is tied to L1, but L2 has a 500 watt draw, and the inverter did not throttle down fast enough when that 300 watt threshold was met, would you still have a 500 watt cushion because the electric meter is reading the total of both L1&L2?
5. Any particular inverter in the 6-8kW range that would do this?
The reason I ask, is I live rural (where you can do pretty much whatever you want) and for many years I was running a small grid-tie setup. I never generated more than I was using, but one day all of the planets lined up and I back-fed a little. The electric company (that had put in smart meters a few months earlier) called me up and asked about it. It should be noted that the two previous times my meter was changed out, they saw my solar setup and couldn't care less. But around the time of the smart meters, they had teamed up with some solar company, and that is when the flood of red tape came about. It was too much hassle to change things the way they wanted, so I switched to a solar-battery-inverter setup to power just certain loads like my pool pump and sheds. But now I want to go back to a grid-tie system but do not want another call from them.
