sunshine_eggo
Happy Breffast!
With a Prius it's more appropriate to refer to the synergy drive system being ON, rather than to use the term "sit and idle".
Thank you for telling me how to refer to a platform I've been servicing for 8 years. Unfortunately, you are wrong. The most appropriate reference would be to say "in READY mode."
I've run an inverter off the 12 volt system many times and the ice engine doesn't turn on every time I put a load on the system. The IC engine only comes on occasionally.
The ICE runs when SoC drops to 40%.
I don’t know how well the IC engine is matched (efficiency wise) to the traction battery charging load when the car is sitting but it definitely outputs more power than can be drawn off the 12 volt system.
I've literally told you about 4000W above.
I totally agree but one must also consider the duty cycle that each engine must run and taking into account the often non constant load that is being powered.
Nope. We're comparing fixed rate 4kW power generation. Generator auto-start is a readily attainable feature, so duty cycle isn't relevant. A dedicated generator can be programmed to come on at X% SoC and shut off at Y% SoC. Or one can manually start/stop a traditional generator. I don't think anyone with an inverter and battery is going to run a 5kW generator when the load is only 100W.
Again, I totally agree, but for fuel efficiency determination one must take into account the duty cycle that each is required to operate under the load conditions, especially if the load on the 12 volt system is not constant.
See above.
