Hi there
I could really use some advice on my current solar setup
I was very green 6 months ago, purchased 2x250 panels, a Renogy 40amp mppt charger , chucked them on the roof of the caravan and though life would be perfect.
Unfortunately these panels never produced more than 190w combined. Got burned by cheap eBay panels that sounded like quality.
Next, I purchased a 200w panel, seemed better quality. Before installing I disconnected the other panels and connected directly to the Renogy, angled it at the sun and saw 160w without trying, thought, beauty, whacked it on the roof (flat roof mount that is).
Reality is that it doesn’t produce more than about 100w once installed.
So I am at a quandary. Is this ‘normal’ output. Is it a controller issue, cabling issue? A. User Issue or something simple.
So I’ll clear up the install a little. I ran 8awg cable from controller to roof, I thought it easiest to just crimp ring connectors on the end, and use a bolt n nut style connection shrink wrapped. thsts how the 3 panels on their standard cable terminate together. Is this okay? I thought this would be fine. My crimps are nice and strong.
Anyone have experience with the Renogy controller? Are they good?
Where should I go from here?
Cheers
Ryan
Cheers
Ryan
