Portable diesel heater
G00SE
There’s two O’s in G00SE
NAZ
Seems these have been gaining popularity.
I had considered building one into a pelican case and then I stumbled upon this one on YouTube last night. Snagged one for the homestead, camper, shop, or just to have as backup heat
With coupon was only 209 delivered.
8kw heat output, 6L diesel capacity, 20lbs in weight, pelican style case, 12hr run time, 900w on start up. Can be 120 or 12v
It’s got a tube to feed air to keep the physical unit outside as well
I should have bought that one, but didn't know it existed. I grabbed the Vevor indoor unit and use it outdoors only. It has automatic elevation settings that will benefit as I travel up or down in elevation, as high as 10'k in the summer. Its an amazing device that I love the hell out of. The pic below was prep for the rain. I put plastic over the control panel and the fuel can where the intake is so the rain wouldn't get sucked in there as much.
A buddy just got that model for a recent trip to Joshua Tree. I have an older AIO model Hcalory. I customized mine and have it mounted to a tire step, as I use it maybe 6x/year didnt feel the need to install it in the van and take up more free space I dont conveniently have.
Sorry about the silhouette pic:
How was Joshua tree?
Anyone have a good link bookmarked for cleaning these?
Are the gaskets universal?
I just picked up a "portable" one my from my brother's. I think it might be a little sooted up... I told him he could mix a little used oil in...
Loving mine. I also went with an hcalory unit. I can get about 24hrs off of 5l with it running at half setting.
127w at startup for a few minutes then it is 27w or less depending on gear selection. Over a 130hr block i used 5 gallons fuel and 2kw of electricity to heat 200 sqft.
Edit:
Anyone else find the “hidden” fuel gauge?
A place I worked at had a similar one in the shop ever winter. It always worked great (provided you have diesel stocked 😉)
