nosolarjpn
biker chick
- Sep 4, 2020
- 2
Hello,
I want to have two 12V Renogy 100Ah lifepo4 batteries as "backup" external batteries to supply additional power to my portable power station, a Bluetti 1500Wh (EB150?).
The idea is for the 12V lifepo4s to "charge" the Bluetti when it runs out.
I can't have solar panels, and a "DIY battery bank (i.e: imported Chinese cells)" is off limits. This config would only be used for emergencies (eg: blackout), so I'm opening to charging the 12V batteries and Bluetti using AC grid power.
My question: since the Renogy batteries have a built-in BMS, how do I efficiently "wire" everything for charging the Bluetti, and for charging the batteries?
Here's my plan so far:
1) connect the 12V batteries together (in parallel?)
2) add a battery monitor to check the volts and amps for each battery
3) use a power supply (eg: AC in -> 12V/30A DC out) to convert AC grid power to ~12V (should it be higher than 12V? is 13.5V ok?)
4) make a wire to connect the battery bank to MC4 port of Bluetti
I'm maybe missing some important details here but I can't figure it out. Any help would be appreciated.
EDIT: I am open to more batteries, ex: 4x12V to make a 48V battery bank, and not married to Renogy, I just thought the built-in BMS was convenient/easier.
