apcorob
- Mar 1, 2021
- 37
I am considering replacing my three 120 volt dometic 15k btu air conditioners (approx 1500 watts requiring the generator) with these 24 volt dc units which have a maximum draw of a little less than 1400 watts each (half that once the temperature is stabilized). The pdf with the specs is:
I am not worried at all about firing up the generator (8.5kw 120volt ) anytime it is necessary (I am never in a place I have to be quiet). I am putting these lower profile units on the roof so I can mount a "flat top" "shady" "aircraft carrier" solar panel array of eight 450 watt panels (total 3600) above the air conditioners. With that said I would like to be able to go 14 hours through the night without the generator with only one of the air conditioners working and little else.
I will probably get a Victron Easysolar inverter charger 3000 kva which will be lightly used for musical instruments, the refrig, computers and light use of the microwave.... Our 12 volt draw is small, few led's phones laptops etc.
I am completely unsure how to connect these three heavy power users to the batteries knowing that the could be fired up at the same time. Might even get a 800 watt dc microwave.
I am also unsure, even after reading many posts here, how large a 24 volt Lifepo battery bank I need to make this work comfortably. Please help me with seasoned advice. No need to overkill as the generator is always (24/7) an option.
My absolute number one concern is reliable service. I have no repair facilities within 500 miles of where the bus will spend its time; and, finally, sun is not the problem. I live on the equator in the middle of the rainforest where 98 degrees and 99 percent humidity is the norm.
Please help me with advice on the battery bank and how to wire this. I will hire a pro; but, want to have a good understanding also.
THANK YOU ALL IN ADVANCE FOR YOUR HELP AND ADVICE.
Rob
Rob
