I recently purchased a Power Queen 300ah 12v.
When I received it the voltage was 13.19. After putting it on a LifePo4 6 Amp charger for two days the voltage is now at 13.15.
I changed chargers and used a 20 Amp charger from another system. When the charge is connected it shows 14.6v. But as soon as I disconnect the charger the voltage reads 13.15. From what I can see in online charts that seem low for a fully charged battery.
Any recommendations? Should it return to normal after several cycles of charging discharging?
Or, is this possibly defective?
From this chart here I was expecting 14.4
www.bing.com
Update,
I put a parasitic load on it, an inverter doing nothing for 24 hours. After that I put a small 6 amp LifePO4 charger and let it run until it said it was charged. After completing it was showing 13.35. the PQ state of charge states that a fully charged battery is anything > 13.30. So, perhaps it is ok!
Thanks,
Mike
![www.bing.com](http://www.bing.com/sa/simg/facebook_sharing_5.png)
LifePo4 battery state of charge chart - Bing
Intelligent search from Bing makes it easier to quickly find what you’re looking for and rewards you.
Update,
Thanks,
Mike
