What can I do?Ohms law:
V = I * R
Voltage = Current * Resistance.
Since Current, I = 0A, there should be no change in voltage between the two points. Period.
V = I * R
What can I do?![]()
Tomorrow I will disconnect the panels and post the results.Find the problem. Something is wrong between the battery and the MPPT.
At night with NO sun at all on the solar panels:
MPPT reported voltage:
Meter on MPPT battery terminals:
Meter on Battery terminals:
Here are all the tests carried out:Find the problem. Something is wrong between the battery and the MPPT.
Yes, the panels were charging the batteries. Honestly, I have no idea about the wire... I should check... These are the ones if it helps (https://www.ebay.it/itm/26641410879...lp:3650466&itmmeta=01HZCWD5CA8GT0N459XVXNJQTG). They are the 10 mm² ones.With panels connected, was any current flowing?
Are you using solid wire or coarse strand wire? You should only use fine strand wire with these:
Yes, the panels were charging the batteries. Honestly, I have no idea about the wire... I should check... These are the ones if it helps (https://www.ebay.it/itm/266414108796?itmprp=cksum:26641410879686019fdba0ea4cc08274d017f998b11f|enc:AQAJAAABUPuhkRI%2B91UKQWudeuFB0sxSbl8Kf7q2qAJkBq6SyaHCakjtWkOM6RXwX38EBShHsGnXFLZW44lqs7elgBvFWTvUzfAG7on%2B4P2hmnCEzJt%2Bv5efZJuLU3QdWwNtsCw6mC8k6bFHyjwpTwVNSOHKTlAd9dlL1z5aTGGnd0DqPaG63x5kYQCsUb2N2s%2BVdJImOGYQXWCK5M9lv41Bi2lCxFsDqx6K1LiicIs5%2FZ4hfVkPeHHx5OTF9R2iVXDpjg79IxcI4axWjbnQZAGKFA0VRf1dfXDmxKWbxfRLca6dabYu0Km8itMLFjbfrQVHF6rt1QH0dFtJ2YxaqX8pVcuIdVXy9oWxrhnN1q7ehi2jnoS0DGbJHzOFErroecqygR6s9J9IknsghXYgY8FKo7NAghiirNW4Ej9DCPrO%2F7r9UxHukCNd64cqEQDqmbvvPB2WeQ%3D%3D|ampidL_CLK|clp:3650466&itmmeta=01HZCWD5CA8GT0N459XVXNJQTG). They are the 10 mm² ones.
Hahaha, okay, I’ll do it tomorrow! But what’s wrong now? Isn’t it normal for the voltage to increase if the batteries are charging?I suspect you can compare your wire to those pictures easier than I can read Italian.
Here I am, I imagine it's the fourth type.Yes, but how much it increases is important.
I was doing an experiment earlier. MPPT reported/terminals measured 14.2V. Battery terminals measured 13.85V. About 20A was flowing.
This 0.35V difference made the connections so hot, I couldn't touch them. I altered the connection and cut the drop to about 0.2V, and the temperature dropped notably.
No, questo è un cavo identico a quello che ho installato, e ho scattato una foto solo a scopo dimostrativo. Scusate se non l'ho specificato prima. Il filo installato è in rame pulito; questa, invece, l'ho usata per avviare il furgone visto che era di scorta ed è diventato incandescente.Sicuramente non fine filo, ma non terribile.
Quello che mi aspetto di vedere quando guardo il filo spellato è un colore rame brillante. Quello che sto vedendo con il tuo filo è uno scolorimento. Questo è tipico della corrosione e del calore. Se dovessi fare un'ipotesi, direi che il filo è bruciato, corroso o ha un rivestimento indesiderato sui trefoli.
Se bruciato o corroso, potrebbe trattarsi di una cattiva connessione (scarso contatto o semplicemente allentato) nel terminale MPPT.
Puoi tagliare quella parte e spellare il filo fresco per vedere che aspetto ha?
No, this is an identical cable to the one I installed, and I took a photo for demonstration purposes only. Sorry if I didn't specify it earlier. The installed wire is clean copper; However, I used this one to start the van since it was a spare and became hot.
So what do you think? Is the system okay as it is, or do you think any modifications are needed?understood
Ok, thanks for your helptighten those terminals down hard. If you get the charge voltage and current you expect, and there is no heat being generated anywhere between the battery terminals and the MPPT battery terminals, you should be good.
