Hello Everyone,
I'm close to getting my permission to sell back solar to my power company. This has been a 100% self install so far as I've had an ATS with a disconnect in it. I just got word back that the ATS with disconnect isn't acceptable and I'll have to install a knife style disconnect. I'm looking to see if anyone has any specific recommendations. Doing some searching, I've seen quite a few different options. I don't have any inspection / permitting requirements so I can do the work myself I just want to make sure I get the proper hardware. The last thing I want is to get something and install it, just to have them reject it.
Here's an excerpt from their document:
As permitted by IEEE Std 1547™-2018 Clause 4.8, a readily accessible, lockable, visible-break isolation
device shall be located between the Area EPS and the DER.
AEP will only allow a single isolation device between the Area EPS and all DER connecting to the Area
EPS at a customer’s premise. This single isolation device is required to allow the company to isolate
all DER at the premise with a single operation. The company may require this isolation device to be
properly fused for the size (ampacity) of the wires in a “line side tap” connection configuration.
A knife-blade switch that conforms with the National Electric Code and has a visible break/open is an
example of an appropriate isolation device for overhead installations. The Safety Disconnect Switch
required by the 2020 National Electric Code may serve as an appropriate manual isolation device in
some installations.
Are there specific models that people like / have had good luck with / recommend?
Thanks!
some installations.
Thanks!
