Hi All. What's the best way to connect communication between EG4 LL-S batteries, EG4 inverters and SolarAssistant?
I've got the batteries comm connected to the inverters and the inverters to SA but I would like to see details of batteries like here:
solar-assistant.io
I could set inverters to USE (user set, charge by voltage) and then connect the batteries comm to SA - not sure if that's the best approach - not sure how important is it to have direct comm between batteries and inverters.
The major reason is I have large discrepancies between batteries SOC (up to 20%. while voltage is almost exactly the same) and would like to see individual SOCs remotely.
Thanks.
EG4 battery setup in SolarAssistant
How to connect an EG4 battery to SolarAssistant.
Thanks.
