Inq720
Odysseus, expert on the Siren's call
First post, but I have been doing a lot of reading on the forum and watching Will's videos to educate myself. I want to put together my first system for my small sailboat. This is merely to replace two deep cycle lead acid batteries (one to start motor, one house). I'll try to primarily run everything off 12VDC like lighting, marine electronics (chart plotter, eventual radar, sonar, etc) and a small fridge will be the largest user. I will get a sine-wave inverter in the 1200W range, but really have no regular use planned for it. It'll be for things like charging laptops and maybe a blender.
I've been reading about the other components needed - controller, BMS, inverter.
The high-lights, so far...
Does anyone have any suggestions for smaller controllers that will handle this system?
I also would like to replace both batteries with this one-battery system, but want to be able to start the gas motor and be charged by the motor's alternator (20 Amp). Is this a matter of different circuitry or just running it into the same charge controller. Will has a suggested system that will do this, but I'm not sure I understand all the nuances. I also can't seem to find anything about the VHF interference on this controller.
Thanks all.
- ~270 Ah / 12 V set of batteries - looking to order through Michael on the group buy thread.
- Overkill Solar BMS that Will suggests
- (2) 100 W Rich solar panels that Will suggests
Thanks all.
