CindySweden
- Apr 4, 2021
- 13
Hi guys,
Thanks a lot for a amazing forum, Im learning a lot. Im very new to this and consider my skills being very basic.
I have a 4s 12v 100Ah LiFepo4 battery and just orded a Overkill solar BMS.
I have a solar panel that came with a PWM that only got settings for sealed/gel/wet (see chart below). Is any setting ok to use with my lithium battery? I understad that it might not be optimal charging, but will it hurt my battery with any of these settings or will my BMS protect the battery? If its not hurting the battery or causing any trouble besides no optimal charging, which setting should I use?
Thanks again guys.
Cheers for a snowy Sweden!
Thanks again guys.
