I am in the process of building my own 7.2kw grid tied system using TRINA 180w Da01 modules I have 46 and have started a small array using 8 in pairs of 2 in parallel to each of the 4 channels on my QS1 and have seen quite large disparities between the 4 channels even though all the modules are in direct sun without shading. channel 2 is always showing 2 watts which means no output, but when I check at the back of the panel as I can pull off the junction box cover and check the voltage and the amperage output at each pair as they are wired they are all putting out between 9 and 10 amps. is this overloading the QS1? Also I had one pair tied in using a set of short cables designed to parallel 2 into one and found that it was not allowing the amperage of both modules to be delivered? I replaced the cable with the solid one piece two to one connector and now all pairs are putting out the correct amount of power...but the ECU app is showing channel 2 is not and the other 3 are miss matched in the amount of power output? I am glad I did this test before I purchase another 3 microinverters as I believe there is some issues with these QS1 Micro inverters but now I have over a grand tied into these 3 and the trunk cable This pole mounted set took too much time and I will be ground mounting the rest a single long ground mount array that is 5 modules in landscape high and 8 rows wide. As my local town is asking 10 dollars for the permit fee PER MODULE before any of the other permit fees, I am building a "Portable Mounted Solar array that be plugging in and unplugged as well as the pipes will be able to be unbolted from the pipes that are cemented into the ground like the one from a local solar array nearby in the photo you can see they have mechanical fasteners bolting the array piping to slightly larger pipes that are buried. I am hoping I can get this thru an inspection. The Power company is not having any problem with the documentation I provided on the modules and the QS 1 micro inverters by AP systems and have tentatively approved me for a 7.2KW system which was the original plan to use 6 of the QS1 microinverters and tie 8 modules of 180 watt each in pairs (360 watt) max amperage 10 amps to each of the 4 channels in two strings of 3 QS 1s each string will go to 20 amp 240 volt double pole breaker in the garage. I am hoping they don't insist on a gfci or arc fault breaker on this system because it will not be able to back feed thru one of those breakers. My biggest concern now is finding out AP systems will not help with Do it yourself installations I went with their system because of the simplicity of not having to have so many parts as now with solar edge in addition to the central inverter you also have to get each module a power optimizer which adds so much more cost. I found these modules from a craigs listing that was from a auction purchase on several pallets of TRINA 180W DA01 modules. They are new and have no damage. The only problem is all the connectors are not MC4 they are a different sytle that is not in use called TYCO connectors. I have been swapping them out for MC 4 and will have to make up several longer extensions to rech all of the 8 modules to each of the QS1s. My biggest concern if they cannot handle the 360 watts and 10 amps each Chanel I will have to redesign everything. the photo of the raking system I planned on using is below I am using the Iron ridge system for the rails and the mounting except for the top caps which are $35 each and I am making for about $10 because I need 16 so instead of $560 I will spend under $160 the side rails also are $12 each from Iron Ridge for an Item that I can produce for $6 and for the required 32 I will spend $192 instead of the $384. I am buying all the bonding fasteners these 2 photos are not my system but what I am hoping to build. I just found out due to covid 19 the local adj will not be coming out and I just have to sign a document that everything is to code! Any advice on the Microinverters will be greatly appreciated.
