MikeSpeegle
I just found out I need to use both sets of terminals. I have 4/0 welding wire from Victron and 2/0 for each 51.2v 250ah series string and 1/0 between batteries in string. I have 250 amp fuses in the Victron for each parallel string and a 500 amp fuse which will only trigger in with a problem as 15k would never use more than 275 amps.
Now they say I need two sets of wires 4/0 to each pole in SolArk. Can I use a 500amp 3 pole busbar after the switch and shunt to send two wires. Will my short runs to fuse and switch be ok?
Or should I use Y adapters from home grid on my already ran 4/0 cable?
Not trying to pin someone with an answer just asking for suggestions that I will take full responsibility using.
Last question are the two black rings for the battery cables necessary because I forgot them.
Thanks!!!!
Thanks!!!!
