I got a new LiFePO4 battery (12V 100 amp-hour capacity) about 4 weeks ago and have been using it in my RV as a standalone (not integrated with the RV system) power source for a 12V inverter. The discharge rate during use is typically 60-100 watts (call it 5-10 amps— usually Starlink and a reasonably efficient laptop).
I’m charging it with a 200W solar panel through a grape solar MPPT charge controller.
I’ve fitted it with a Victron Smart Shunt, which I have set up to take 14.2 volts as full, and resets itself to 100% when charged to this voltage (every sunny day so far).
Yesterday was the first day I discharged it by more than about 30 amp hours from full. The system worked well discharging at 90W until it reached 65 amp-hours of discharge (i.e. nominally still having a charge of 35 a.h.). Temperature was about 65F.
I was expecting to be able to continuing to operate until discharging more like 80 amp-hours.
Is this common? Is this one of those things that separate the better batteries from the less-so?
