My system:
5 - 100w panels in series
24v 120ah LiFePo4 battery bank ( 60ah cells connected parallel in sets of 2, then the 8 sets connected in series.)
200amp Samlex Battery Guard
2000 watt Samlex Pure Sine Wave inverter
Tracer 4215bn charge controller w/ MT-50 remote
I'm looking for recommended settings for the charge controller. I found this post https://diysolarforum.com/threads/r...e-for-diy-lifepo4-batteries-sticky-post.5101/ but the Epever has several settings without any real explanation of what they are. I think most of them apply to lead acid and aren't needed for LiFePo4, but that leaves me unsure how to set them.
Here are the settings:
Over Voltage Disconnect Voltage
Charging Limit Voltage
Over Voltage Reconnect Voltage
Equalize Charging Voltage
Boost Charging Voltage
Float Charging Voltage
Boost Reconnect Charging Voltage
Low Voltage Reconnect Voltage
Under Voltage Warning Reconnect Voltage
Under Volt. Warning Volt.
Low Volt. Disconnect Volt.
Discharging Limit Voltage
Equalize Duration (min.)
Boost Duration (min.)
Thanks for any help you can give me with this.
Tim
Tim
