pezzodefero
- Nov 16, 2020
- 5
hello Friends,
I looked in the forum, but I wasn't able to find and answer so far?
I was wondering if any of you can help me with the "situation":
we know that the DCC50S charge at max 50 amp, and if you drive at night with NO solar, it will get the 50amp from the alternator,
the "problem" is when you drive even with a small amount of solar the charger will split charge beetween SOLAR and alternator, resulting in 25AMP + any AMP that solar can provide resulting (in my case 300w solar on my roof) in a not very efficient charge while driving during the day( most of the time)
How can put a switch on the wire coming from the solar panel, but then i have to remember to switch it ON every time I'm not driving.
I think using a relay Normally closed on the solar wire that open the circuit while it recive current from the ALT would work, but I'have no idea on which relay use.
I'm in canada and would be easier to buy something from amazon
did anybody accomplish this?
thanks in advance
Gabriele
thanks in advance
Gabriele
