Hi all - I have a Renogy Lycan 5000 which has the RIV4835CSH1S-US inverter inside. I've been working on a monitoring system so I can pull all the info into my home automation system but I couldn't find any information on Modbus registers for this unit. There's info out there for the smart batteries, but I couldn't find anything for this inverter. I've spent some time mapping out the registers myself and wanted to share what I have so far in case it's helpful to anyone else. These are all holding registers. The model name spans 8 registers.
RegName | RegAddress | Notes |
Inverter UEI Volts | 4000 | |
Inverter UEI Amps | 4001 | |
Inverter Voltage | 4002 | |
Inverter Load Amps | 4003 | |
Inverter Hz | 4004 | |
Inverter Battery Voltage | 4005 | |
Inverter Temperature | 4006 | |
Inverter Model 1 | 4311 | |
Inverter Model 2 | 4312 | |
Inverter Model 3 | 4313 | |
Inverter Model 4 | 4314 | |
Inverter Model 5 | 4315 | |
Inverter Model 6 | 4316 | |
Inverter Model 7 | 4317 | |
Inverter Model 8 | 4318 | |
Solar Volts | 4329 | |
Solar Amps | 4330 | |
Solar Watts | 4331 | |
Charging Status | 4332 | (0=Not Charging, 1=Bulk, 2=Boost, 4=Float, 6=Lithium Activation) |
Inverter Charging Watts | 4333 | |
Charging Status? | 4405 | Not sure on this one, but changes from 4 to 5 when generator shut off |
Inverter Load Watts | 4410 | |
Inverter Charging Amps | 4412 | |
UEI Hz? | 4442 | |
