I would like to replace my BMS
Can someone give me some guidance on how to remove the BMS from the battery pack???
Start by removing balance lead wires on BMS, then cut the P- wires on old BMS going to Anderson connectors, then cut the B- wires going to battery negative???
The new BMS has ring terminals attached..
My worries or concern is adding ring terminals to battery negative wires attached to battery..
I do not want to short my battery by adding the ring terminals or would adding the ring terminals to battery negative wires create a short???
little insight would be appreciated
