It is possible for solar panels to cause a roof leak, although it is relatively rare. When solar panels are installed on a roof, the roof must be penetrated to secure the panels in place. This creates a potential pathway for water to enter the roof if the installation is not done correctly.
If you are experiencing a roof leak that you suspect may be caused by your solar panels, it is important to have the issue diagnosed and repaired by a qualified professional. The first step would be to identify the source of the leak, which may require removing some of the solar panels to inspect the area where the roof was penetrated during installation.
Once the source of the leak is identified, it can be repaired by sealing the area around the penetration with an appropriate sealant or flashing. If the damage is more extensive, you may need to have the entire roof repaired or replaced.
If you believe that the solar panel installation was not done correctly, you may need to contact the company or contractor that installed the panels to have them address the issue. It's important to work with a reputable and experienced contractor when installing solar panels to ensure that the job is done correctly and to avoid potential issues like roof leaks.
