mike2scuba
- Dec 13, 2022
- 94
Not used these before so advice needed
Do the connection range only go from sc6 to sc10. No sc8
Was going to use 10agw cable but have measured my shunt terminals and they are 10mm. On looking at the SC terminal chart on the internet I cant get a 10awg to 10mm only sc6-8
So am thinking I will need sc10-10 terminals and have to upgrade the cable to AWG8 to connect to the shunt and onto to the 8mm busbar terminal using a SC10-8
Does that sound correct or is there another way on a 30amp system
Also if I decided to add a 1000 watt inverter what agw would I be best using up to the busbar from the battery
