T thomBangor New Member Joined Jun 5, 2024 Messages 83 Location Bangor, ME Thursday at 7:13 AM #1 After lots of feedback from this forum, I think I'm going to go with this design. If you find any holes in it please let me know.
stienman Mostly Harmless Joined Jan 6, 2021 Messages 489 Thursday at 9:00 AM #3 The ATS will go between the inverter, panel, and subpanel, not just the panel and subpanel. For the inverter to ATS run use conduit so you can replace the wires later with heavier gauge wires as you upgrade without digging another trench.
T thomBangor New Member Joined Jun 5, 2024 Messages 83 Location Bangor, ME Thursday at 9:17 AM #4 stienman said: The ATS will go between the inverter, panel, and subpanel, not just the panel and subpanel. For the inverter to ATS run use conduit so you can replace the wires later with heavier gauge wires as you upgrade without digging another trench. Click to expand... I don't quite understand. Is there a 2nd ATS, or do I have it in between the wrong objects?
T thomBangor New Member Joined Jun 5, 2024 Messages 83 Location Bangor, ME Thursday at 9:24 AM #5 stienman said: The ATS will go between the inverter, panel, and subpanel, not just the panel and subpanel. For the inverter to ATS run use conduit so you can replace the wires later with heavier gauge wires as you upgrade without digging another trench. Click to expand... Like this maybe?
T thomBangor New Member Joined Jun 5, 2024 Messages 83 Location Bangor, ME Thursday at 9:40 AM #6 I have revised my diagram. If I understand right, the inverter goes on the ATS 'main power' and the grid/panel goes on the ATS 'emergency power'. My subpanel/appliances are on the 'Load'. Does that sound correct?
stienman Mostly Harmless Joined Jan 6, 2021 Messages 489 Thursday at 9:44 AM #7 Yes, the ATS chooses the power source, then feeds it to the subpanel. The new diagram is better.
