I have 4 200w solar panels that I want to wire in series-parallel on top of my travel trailer (currently only have 1 200w panel). I plan to use a 20a fuse for each string. I have a 12v 200ah LifePo4 battery, 60a MMPT solar charge controller and 1000w inverter.
Question #1: how do I calculate the total output (in volts/amps/watts) this configuration will send to my solar controller?
Question #2: if the voltage is more than 12v, does the solar controller regulate that to ensure only 12v is going to the battery (probably not good sending 24v to a 12v battery).
Question #3: I want to ensure I'm using large enough wire throughout the system. Will 6 awg be enough? (that is the max my solar controller will accept). I also have 2 awg from the inverter to the battery.
