David B.
I am in the planning stages of my solar design. Currently I have a question about series-parallel.
I'm using 12 canadian 46.8 v 390 watt panels. I think my first calculation is correct,
4 panels wired series-parallel=46.8v @ 16 amps 12ga wire to inverter.
Now this where I'm not sure what happens to volts and current(amps) when I add the remaining 8 panels using the same series-parallel wiring to complete the string. Does the voltage and amps change as I add panels? With 12 panels what would my numbers be?
