Mahendra Gomanie
I am trying to figureout if I missed any knowledge on mppt charge controllers and solar panels.
The system is 12v off grid .All items mentioned are on hand .It’s just a question of the 10-60w panel configuration.
I have 10 60w bp solar panels with the following specs
My thought are to put these in two series strings of 5 to save on wire breakers ease of installation etc.
I friend of mine however ,advised against series strings and suggested that 5 parallel strings of two in parallel(basically 10strings on 5breakers) should be done basing his ideas that each panel would not be protected by breakers and that there would be losses due to the series configuration.
I honestly do not see much merit in this .Please share your thoughts.Are the losses due to series strings justifiable?
STC Power Rating Pmp (W) | 60 |
Open Circuit Voltage Voc (V) | 21.0 |
Short Circuit Current Isc (A) | 3.87 |
Voltage at Maximim Power Vmp (V) | 16.8 |
Current at Maximim Power Imp (A) | 3.56 |
Panel Efficiency | 10.8% |
Fill Factor | 73.8% |
Power Tolerance | -3.00% ~ 3.00% |
Maximum System Voltage Vmax (V) | 600 |
