Hi guys!
Possibly another silly question, but I'd like to make sure I fully understand before building my system.
I'm in the process of converting a van into a camper and have a 24v 280ah battery system. It will be charged via a Victron EasySolar GX II 24/3000/70 that I got second hand.
Going into this, I knew that I would most likely have to get panels that were wired in series in order to deliver enough voltage to charge the batteries. However I wanted to avoid this if at all possible due to the fact that there will be limited roof space to begin with and my understanding is that if a panel in series is shaded every other panel in the chain is knocked out too. I would not have enough space to wire pairs in series and then connect them in parallel.
Then I discovered the Perlight 415w mono panels which I could comfortably fit 2 panels of, and have space for additional fans etc.
The specs are:
I contacted the company selling them to check my configuration and they are saying that even with these I would need to run them in series to have a hope of getting enough voltage to charge the battery. Their entire business is solar installation so I have no reason to disbelieve them, but I wondered if anybody could help me understand why these would not work in parallel at a reasonable level with the 46.7 open circuit voltage. I may be missing something very simple!
Thanks in advance!
The specs are:
Maximum Power Voltage - Vmpp(V) | 38.9 |
Maximum Power Current - Impp(A) | 10.67 |
Open Circuit Voltage - Voc(V) | 46.7 |
Short Circuit Current - Isc (A) | 11.12 |
Panel Efficiency (%) | 21.2 |
Thanks in advance!
