Capt Tango
Expecting more Mojo than I'm getting.
Here's the hardware:
Panels
4 Ea. QCells 400W Solar Panels 1,600 watts total
Open Circuit Voltage (VOC): 45.30V
Short Circuit Current (ISC): 11.14 A
Maximum Power Voltage (VMP): 37.13 V
Maximum Power Current (IMP): 10.77 A
Maximum System Voltage: 1000 V
Maximum Series Fuse Rating: 20 A
Charge Controller: Set to the LiFPO setting
Victron Energy BlueSolar MPPT Tr VE.Can 150V 100 amp
Batteries
2 Ea. FOIIOE VESTWOODS 300Ah 200A BMS 600 AH Total.
DC Circuit Breaker:
DIHOOL 60 Amp Solar Disconnect Switch, dc Circuit Breaker
Magnum Energy 3000W 12V Inverter/charger 125 Amp MSH-3012RV $1,773.97
Magnum Energy Remote Control for All Magnum Inverters 50' Cable ME-RC50-L $180.00
Magnum Energy Automatic Generator Start Module Network Version ME-AGS-N $230.00
Magnum Energy Battery Monitor Kit With Shunt ME-BMK-NS $169.00
The panels are flat installed and wired in Parallel using 8 AGW wire to a positive and negative bus bars on the roof of a Class A motorhome. 8 AGW wires go to a PV disconnect then to the MPPT Solar Controller. The final connection between the controller and the batteries is also 8 AGW.
I'm in Arizona and pulled in about 400 Watts between 11:30 to 2:00 bulk charging with SOC reading of 42% and 24% increasing .5% and hour than it swung up and down from 200 to 500 watts in absorb mode ending the day at 46% and 26%.. Just before changing to Absorb, I heard a clicking sound coming from the controller.
I was expecting at least 800 watts due to winter angle of the sun and being flat mounted. Could the 8 AGW wires coming out of the MPPT be too small and should I wire the panels 2S/2P?
Panels
Batteries
DC Circuit Breaker:
