Capt Tango
I am YouTube Certified Solar novice and just purchased 2 Ea. FOIIOE VESTWOODS 12V 300Ah 200A BMS LiFePO4s and have a few questions.
1. I had to buy from two different Amazon post because they only allowed 1 battery purchase per order. One was an "Ultra" for $649 the other was a "Plus" for $629, what's the difference between the two other than price?
2. I'm doing the initial charge, charging one battery at a time. I just looked at the charger readings after 8 hours at the 20 Amp setting and I'm getting 14.6 volts but only 163 AH. Does that mean I need another 7 hours to bring it up to the rated 300 AH? 300 - 163 AH Divided by 20 Amps + 6.85 Hours?
3. With 600AH @ 12Volts battery pack how many watts should I have with flat mounted panels on the roof of an RV? I'm considering 4 Ea. 400 Watt panels.
4. With less than perfect solar conditions while boon docking is it best to go all parallel or parallel/series? I'm using a 150/100 MPPT and 8 AGW so I think I'm okay down stream.
